chubbysauto
Vin#1D7HA16D53J677601
2003 Dodge Pickup 1500 5.7
Need help figuring out this problem. This is a customer's truck. They first brought it for a intermittent no-start after driving for a while. P0172 -Fuel System Rich.
I could hear the fuel pump whining. I checked the fuel pressure and it was 90+ to 100psi. Normal is around 45-60 PSI. So I figured the fuel pressure regulator on top of the actual fuel pump. I replaced the entire fuel pump with the fuel pressure regulator. Fuel pressure dropped to normal 45-60 PSI. Customer picked it up and it drove fine for a week or two.
Comes back, same whining, same high fuel pressure. Truck doesn't want to start after they drive for a bit.
So I figured the brand of product they purchased. I switched brands. Fuel pressure dropped back to normal, 45-60 PSI. Ran good for another 2-3 weeks, then same. Pump whining.
Actually, whining noise is coming from fuel pressure regulator. So I'm going to warranty this pump again, but i want to check and see WHAT IS KILLING THESE FPRs? I blew out the fuel line but there is only ONE fuel line. No return. Just one singular pressured line to the fuel rail. I also remember that the truck was having evap codes but i never got a chance to check it out. What if the fuel tank is staying pressurized? EVAP system not purging out pressure? That increased pressure is killing the FPR?
I'm lost and the customer is understanding, but i need to get this fixed.
Thanks.
Thanks.
