Oil pressure help!!
Dodgeprob
5.7l
Was having trouble with oil pressure dropping to zero when stopped at a light But came right back up. Changed the pressure sending unit and it still happened. Then changed the oil, filter, and pump. Now when started have no oil pressure. Any suggestions?
Shadow_Death
Killeen, Tx
Did you seat the pump completely before bolting it in? From what I get out of it if you don't and you bolt it in then you can crack the pump.
Gr8bawana
6.7 CTD
Sounds like it could be something as simple as a bad connection.
Yeret
Professional Procrastinator
Behind a computer saying, "looks easy enough..."
5.9 Magnum
Does the engine tick or chatter when the oil pressure sits at zero? I had this issue for a while after I had the original pressure sender replaced with a store brand one. I replaced that with an genuine OEM replacement and haven't had a problem since. Sucker set me back $55 but hey, it actually works!
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
May want to try the sensor as well, not sure if you tried that already. Happened in my lowered dodge before it was lowered. Still ran and drove fine, just wouldnt register oil pressure.
joshhhh
