Outside air temp display always reads 130 F Sensor?
Joe.G
2004 SLT Quad Cab Short Bed
Hi, my 04 SLT 1500 Hemi, the overhead display always reads 130 F, is there a sensor or something that I should replace? thanks
Sheerider93
I had this issue too a few weeks ago but after cold resetting the truck (unplugging battery for a few minutes) it read normal. It may take a few resets to get it back though, or at least I did.
derekp
Buda, Tx
1990 5.9 Cummins
The sensor is in front behind the grille usually near a headlight. I would try resetting the computer first, you can always replace it later.
Sheerider93
I was about to drive to get a new sensor when I had this issue until I just reset the computer, saved me $20 and a drive to Advanced Auto Parts lol
J
Joe.G
Yes the Battery was replaced and computer has been reset. Maybe give it a little bit and see if it straightens out?
derekp
Buda, Tx
1990 5.9 Cummins
Yeah, give it a few days of driving to reset. More than likely it will fix itself.
J
Joe.G
Does the reset button on the display do anything for the temp?
hotkarl
4.7 Semi-Hemi
Had a similar thing a few weeks ago. Was stuck on 39 and it was 60 outside. Like a day or 2 later it was fine.
J
Joe.G
Replaced the sensor Problem solved.
ameer73
