geezer336
Where do I get one on the cheap for my 18 Tradesman ? Don't need a fancy one just the lights mainly .
If the truck does not come with overhead console from the factory it will not have the CV2 or the CUN sales code enabled or any of the correct wiring so neither the compass or the Homelink will function untill those codes are set plus all the correct wiring added.I know it's a bit early, but I would scour pull a part or eBay.
If lucky enough you can get one with homelink.
The last 4 homelink I have salvaged for other cars were basically self enclosed as a unit. Wire power and you're good. Now I don't doubt the Ramholes did something different.If the truck does not come with overhead console from the factory it will not have the CV2 or the CUN sales code enabled or any of the correct wiring so neither the compass or the Homelink will function untill those codes are set plus all the correct wiring added.
Sent from my SCH-I545 using Tapatalk
