Overhead console ?
geezer336
S.E. Oklahoma
Where do I get one on the cheap for my 18 Tradesman ? Don't need a fancy one just the lights mainly .
UnsatFC
Active duty NAVY
New Jersey
Every now and then a fellow member will post one on this forum....eBay if you want one now.
misfit77
I know it's a bit early, but I would scour pull a part or eBay.
If lucky enough you can get one with homelink.
78Staff
US Navy Veteran
NE Florida
I've got one including the mounting bracket - Black, LED lights, slider switch, no homelink - shoot me a PM.
Ricks Ram
If the truck does not come with overhead console from the factory it will not have the CV2 or the CUN sales code enabled or any of the correct wiring so neither the compass or the Homelink will function untill those codes are set plus all the correct wiring added.
Sent from my SCH-I545 using Tapatalk
misfit77
The last 4 homelink I have salvaged for other cars were basically self enclosed as a unit. Wire power and you're good. Now I don't doubt the Ramholes did something different.
circuitguy
Elk Grove, CA
2017 Ram Tradesman Regular Cab
5.7L HEMI
Just run power, ground and then tap the rear dome light so the new lights will turn on the same with the doors. Easy to do.
Jantelaw
