dapepper9
- Feb 7, 2013
- 5,906
- 2,227
- Location
- Iowa/Nebraska Border
- 2001
- 5.9L V8
I have 2 check engine codes right now P1740 and P1764. Torque Conveter and Governor Pressure Sensor according to the codes list in the tech info sticky. I'm 99% sure the t/c code is because of the shift solenoid because it did the same thing when I had a bad 02 sensor. My question is what does the solenoid do (idk much about trannys) and would I need an A/Trans Governor Repair Kit to fix it? From what I can tell on Youtube its a fairly easy process of draining fluid, taking off the filter, and unbolting the bracket.
