P1763 transmission code
EriikK
Ann Arbor MI USA
1999 Ram 3500 2WD van. My wife's camper van to be exact. It came back from a trip with a P1763 code (governor pressure sensor voltage too high) so I changed out the governor pressure sensor and the solenoid, as well as changing the fluid and filter. But the code won't clear and it starts from a stop in a high gear. If i shift to 1st manually it works fine, feels like the trans is mechanically OK. Seems like I should check for wiring problems, maybe it is as simple as a bad ground. Anybody got any more ideas? Can someone tell me where the connector is that I can probe? Thanks in advance.
