P127E
Helpram
IA
6.7 cummins
Can anyone tell me more about this code, drove home last night seemed to be no power. This am got up and just cranks won’t start. I’ve been reading that it’s the fuel relay and is built in the tipm is this correct have to repacke the tipm not just the relay? Thanks in advance for your help
06 Dodge
Forest Grove, Oregon
6.7L CTD
Duck Duck Go is your friend:
Home DodgeP127E
Dodge.png Dodge DTC P127E​
Make:DodgeCode:p127EDefinition:FUEL PUMP CONTROL CIRCUIT 2 OPENDescription:With the ignition on. The battery voltage greater than 10.4 volts and the Main relay is on. Totally Integrated Power Module (TIPM) requesting Fuel Pump operation. Actual Fuel Pump state is not equal to the desired state. One Trip Fault. Three good trips to turn off the MILCause:
  • (N1) FUEL PUMP CONTROL OUTPUT CIRCUIT OPEN
  • FUEL PUMP
  • TOTALLY INTEGRATED POWER MODULE (TIPM)
