Brandon-W was looking into making them tiptronic,i'm not sure if he's pursued it much yet though. I have paddles in both the truck and the wifes 2019 Challenger.Honestly the ones in the truck are a better set-up then the tiptronic versions in the wifes 1320 Challenger. You can't shift the tiptronic versions anymore in the car then you can in the truck.If the cars not at the right speed it won't let you upshift,and it's a royal pain in the ass leaving a light if the cars shifter happens to get bumped over to manual mode.If i could change the paddles in the car to work more like the paddles in my truck easily,the car would be getting changed,lol. The paddles are virtually instant in both the truck and car as far as shift speed goes when you pull on them "if" you're at the right speed and rpm,if you're not at the right speed or rpm in either one,it's not gonna shift no matter how many times you pull on them ,if your foot is stuck through the floor. I pull the paddles in the truck at roughly 6400 rpm constantly,if your truck is short shifting on you,that's in the tune,you need your tuner to up your shift parameters,i can lock the truck into the gear showing on the evic and it won't upshift past that gear,but it will go into limp mode,lol. As long as the truck is over 5600 rpm,it shifts pretty well instantly using the paddles.5600 rpm is the factories preset shift rpm under that if you have it floored it's not upshifting by itself or by the paddles,same as the car it won't upshift either if you're under the preset factory shift rpm
