Paint bubbles on fender
Hemi395
Cape Cod MA
Yeah wasn't expecting it to look like that. I expected a foam material.
From what I can tell from the pics I took of mine I have no evidence of rust starting around it. However, my truck doesn't go out very often in the road salt as I have a company vehicle so mine might be a bad example.
DIRTRIDER
2019 REBEL
HEMI 5.7
Had this happen on my '14 with only 15,000mi on it. Truck is white. I also had the truck oil bath rust proofed the first week I got it. Dealer knew right away after seeing the paint bubbles the fender would need to be replaced. Rusted right through sheet metal.
Bee1971
Sobieski WI
2011 Sport 4x4
345 Hemi
Pulled my 2011 apart today - Sport 1500 4x4 Quad Cab
Truck is Mint , only 26,000 miles
Well , enjoy the pictures
Now I have to figure out how to treat the one rust spot from the backside that has not bleed through yet
And like mentioned , that fiberglass tape is not coming off
Was also told if I tried to remove it the fender would come with it - It's pre attached to the new fenders straight from Mopar
Bee1971
Sobieski WI
2011 Sport 4x4
345 Hemi
Another
Bee1971
Sobieski WI
2011 Sport 4x4
345 Hemi
Another. Look at mirror
Hemi395
Cape Cod MA
Nice pics, that sure beats the ones I posted!
Damn man that sucks... Maybe try soaking it with wd-40 to displace any moisture and then soak the **** out of that whole area with something like fluid film.
This whole thing is such bs this shouldn't even be a problem...
Bee1971
Sobieski WI
2011 Sport 4x4
345 Hemi
Exactly what I did today on both fenders - That stuff is like rock hard adhesive
Honestly , I think the only way you could get it off is with a grinder , and that's not happening
Talked to some body shops today - They told me it's an bonded material that gives the fender strength or body thickness , the metal is so thin , it's needed to keep the fender from deforming or buckling
$50,000 MSRP 2011 Ram Sport , 26,000 miles , always garaged every night since new , washed regularly - I can't even remember the damn thing even driven in the rain
I got a headache
Hemi395
Cape Cod MA
I got a headache
Thats pretty pathetic if you ask me. Needing a material on the back to keep it from deforming because its so thin?? What do you want for $40000???
So did you have to take the entire front fender liners out to get to it?
Bee1971
Sobieski WI
2011 Sport 4x4
345 Hemi
Front Wheels Off
Ram Mudflaps Off
Wheel Liners Out - Piece Of Cake , Some Of Those Barbed Plastic Plugs Are A Pain , And Watch For The Wiring Harness For Each Sensor That Has A Barb Poking Through The Wheel Wells - Just Push Them Out
Anyways With Those Wheel Wells Removed
Spark Plug Changing Is A BREEZE !!! Wow , So Easy , Even Under The Brake Power Booster
Simple And Fast
Hemi395
Cape Cod MA
Front Wheels Off
Ram Mudflaps Off
Simple And Fast
Awesome thanks I'm definitely doing that soon to mine. So you used fluid film or something similar?
alphaprojects
