painting exhaust tips
tsg2009
Smyrna, De
5.9 magnum
i want to put black exhaust tips on my truck but they are costly is there a way i could paint regular tips black? would normal vht paint work or plasti dip?
schroederMP
Indiana
Cummins
Yea just scuff it up with some sandpaper and hit it with a high heat paint.
WhiteExpress
Midland, TX
I've also had success painting exhaust components (not just the tip...) with High Heat paint.
I really like the finish of the Ceramic high heat paint. It's a low-semi low gloss, but seems to be very hard / impervious once cured (a heat cycle or two)
blackout11
alpharetts GA
2011 R/T
Your best bet use high heat grill paint then high heat clear will look like this
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
did mine too with the high heat paint, took about 30-40 minutes with dry time.
shostopper17
Ive done mine with plasti dip caost me 10 bucks for 2 cans. Did 1 can each on each tip and they are holding up amazing.
tsg2009
tsg2009
Smyrna, De
5.9 magnum
awesome, ima buy some cheap polished stainless tips probably then paint them to use they should look pretty good on my truck
BoBoway4
