Parking sensors giving false signal after aftermarket bumper installed?
Jberry805
California
2014 ram 2500 6.7 ******
Installed a new rear aftermarket bumper and now in reverse the parking sensors are alarming the whole time in reverse?
Is there something I need to check?
Bumper is chassis unlimited octane series
Travelin Ram
Was it DIY or a shop?
Sensors are picky, previous truck I installed tow points on the front to flat tow it. They didn’t protrude; fit in exactly where the tow hooks were. Nonetheless after that the sensors were not happy; they gave me false positives quite often.
J
Jberry805
California
Diy.
I don't see anything that would be causing a false reading
J
Jberry805
California
I did not disccont each sensor, only removed it from the main connection the to truck.
All sensors locked into tabs, only thing I can think of is maybe because the bumper is thicker?
gtomike60
Milford,Mass
5.7L HEMI
My thought is they might be picking up the kickout above the receiver
Justthebutler
BC
2017 Ram 1500 SLT
Are they going from a plastic bumper to a metal one?
Maybe the metal affects them somehow.
Could they be calibrated to specific angles?
There are sensor relocation kits you can get On Amazon or Google. I think they have a way to bypass the false readings and set up a new distance
1911LVR
6.7L SO
Could be the sensor orientation is off. Pretty sure if rotated sideways they don't work properly.
acoffeefiend
USA
I got a Road Armor bumper. Same issue with parking sensors. The instructions said I needed to order new bezel rings for the painted bumper:
Front
5ls52tzzaa outer
5ls53tzzaa middle
5ls54tzzaa inner
Still working on trying to find them from anyone other than Mopar who wants $25 per plastic bezel ring
