Passenger fender rubbing door
Claydus
Ducktown, GA
2020 RAM Rebel
As the title says, my new to me 2020 RAM has a slight issue when opening the passenger door. It rubs the front fender and some paint is chipping off the door. I noticed it this weekend just 3 days after buying the truck.
It appears that the middle and bottom alignment of the fender is not lining up 100% with the door. Or possibly the door isn't lining up with the fender. However, the gaps and measurements between the front and rear passenger door have same gap and alignment from what I can tell. So I am leaning toward the fender being the issue.
I have contacted the dealer to see what can be done about this.
Door closed. Wide shot.
Door closed. Zoomed in. You can almost see how higher the door sits above fender right here.
Opening door. Zoomed in door rubbing.
Straight edge measurements at middle.
This measurement looks fine. Driver side looks like this all the way down.
Straight edge measurements at bottom.
Jim BB
Hamilton ,ON
2019 Ram 1500 classic Express
If you Bought the truck from the dealer take it back have them fix it under warranty ! even used vehicles from a reputable dealer has at least a 30 DAY Warranty !
British Bulldog
Jacksonville NC
Hemi 5.7 etorque
I agree. Take it back sharpish. That will rust in no time wherever you live. Looks like bare metal from the pics. Should be an easy adjustment for any body shop.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
If your dealership is anything like mine they'll refer you to a body shop. Hopefully they'll take care of this on their dime. It's a little late for you now now, but opening all doors, hood, trunk/tailgate to check for clearance is in my normal process when buying used. It's likely that truck was involved in some kind of accident for that to have happened.
tron67j
Maryland
The way the paint is chipping in the door makes it look like there was a repaint done there. Also, check the fender where it meets the inside engine compartment for over spray. That might be a replacement part. Did your vehicle report indicate an accident? Wouldn't always, especially if the prior owner just had someone fix it on their own.
Chumbucket12
The same thing happened to my 2011 1500. but mine was in a really bad accident with over 12 grand of damage to the front of the truck. A GMC SUV landed on my hood head-on. I'm having tons of problems with the truck and this is one of them. My paint is coming off between the passenger fender and the door just like yours but closer to the mirror. I noticed after the repair the passenger bodyline was too close but was told by the horrible shop that it was because it's a ram and that's how they fit. I just noticed the paint a few days ago so it hasn't been remedied yet but I'm assuming some body work has been done to your truck to cause this.
when checking body gaps, i use a paint stick
i have not used that method on anything newer, like yours
Jim BB
Hamilton ,ON
Looks like the bottom of the fender just needs to come out a touch or door in not a big issue easy fix !!!! and blow in the edge of the door and fender !!!! even brand new vehicles have this issue sometimes bolts are not tightened up enough on the panels and they move or alignment tool used moved when tightened up ! when i worked at a dealer we had a collision center where I worked and seen this often .!
Orca
