Passenger side high beam
Bloveless
Wv
I have a 2014 big horn I can not get my passenger side high beam to work I have tryed everything I even bought a tipm and tryed that not getting power to the passenger side however I can take every thing from passenger side and plug it up to driver side and it will work
Phirebeard
NW PA
Did you check the pins in the connector going to the headlight?
B
Bloveless
Wv
Yes cut them out and hard wired it
turkeybird56
Central Texas
Really stupid thought. Gain access, turn on light and use Ohm meter set to see if ne voltage getting to circuit? Internet guessnosis, LOL.
B
Bloveless
Wv
it is not getting any power to the socket that’s why I changed out the tipm but still nothing
Scottly
Safety Harbor, FL
HO 6.7 Cummins
There is the harness inside the housing...that plugs into the facia harness outside the housing. If you have no power to the outside plug, run back from there.
turkeybird56
Central Texas
^^^^^^^^^^^^^^ DITTO ^^^^^^^^^^^^^^^^^^
If the fuses are good, U R gonna have to trace backward till U find the issue, whether ground, shorted wire, frayed, disconnected, just saying. AND I know stuff like that just really suks and is a major PITA.
