Pedal Commander help
Docwagon1776
Midwest
Instead of trying to sift through people's opinions in a forum about how they work, if you really want to know how throttle controllers work, the best thing would be to research them on your own. There's plenty of information out there. Throttle controllers are not a gimmick, they do work. The thing I notice most is there is no initial throttle lag the truck has with no throttle controller.
Plenty of misinformation as well.
Put a block of wood under your pedal that's tall enough that the pedal now 'floors' at 40%. Every time you go to take off, stab it as hard as you can until it 'floors' at 40%. I bet you'll note the exact same feel as a pedal commander that's set to take 10% pedal and increase the voltage to simulate 40%. Etc. etc. It's just easier to modulate because without a hard stop it's very hard for a human to quickly stab the pedal to a set percentage without overshooting or undershooting. Same reason new shooters who ride the reset of the trigger shoot so slow. You can't be both as fast as you can be and as precise as you can be, especially at an untrained/unpracticed movement. Body control has to be taught or we'd all be naturally graceful dancers. The PC isn't a gimmick, it's a crutch to allow more or less granularity so you don't have to be that ballet dancer on the pedal. But it also doesn't do anything past the ECU. It can't, it has no line of communication, and saying "I don't know how it does but it does" isn't information.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
I'm not arguing your shooting analogy, and I resemble that remark with every new rifle I buy. At least until I get used to it. But the block of wood comparison isn't accurate. Doesn't matter how hard you stomp on the gas pedal, there will always be that initial lag before the throttle body opens fully. Pedal controllers eliminate the initial lag that's there from the factory.
rick phillips
Norene TN.
360 cid
It seems a lot of folks, mostly the ones who haven't researched them, don't understand how the controllers work. Think of it this way. Stock FBY is a controller, exactly like the aftermarket ones, except set at factory specs. (speed) and not adjustable. They take appx. 4 sec. to fully open the throttle plate, doesn't matter if you take 4 sec. to push to the pedal to the floor or tromp it as fast as possible, the throttle won't be fully open for appx. 4 sec. With a controller set to the middle setting the exact same thing happens, but within only 2 sec., and on the highest setting the throttle will open almost immediately, just like back when there was a linkage or cable operated throttle. Some controllers have an economy mode, those eco. settings will change the throttle plate response time to an even slower response time than the factory setting, These modes can be duplicated by pushing the pedal slower, but the plus settings could never be duplicated by pushing the pedal faster, the OEM controller won't let it happen.
N2MoPar
Woodland Hills, Ca
I’ve had my pedal commander for two years and never had a problem with it..........and now it sets off the engine light and goes into limp mode more often than I’d like it to
It’s the only modification I’ve done to my truck and I really dig it
Driving my truck with the pedal commander is like when your parents would go out for the night and leave the kids at home with a questionable older sibling in charge. Now, driving my truck......it feels like my parents are always home
I vaguely remember a post on here about a specific sequence to follow when plugging in the pedal commander so that it doesn’t set off the engine light.
Does that sound familiar to anyone.....or did I just pull that thought out of thin air?
Does that sound familiar to anyone.....or did I just pull that thought out of thin airplane
Dan90
2017 Sport
The Pedal Commander has major radio frequency issues. That is why I pulled mine. When off roading using radio comms, the VHF radios trigger the PC and cause it to throw a throttle code and put you in limp mode. That is probably why others have mentioned random encounters of this happening. They likely drove near a signal that caused it to throw a code. EMC emissions are no joke and why OEMs perform so much testing around it.
Someone mentioned they were near a construction site on the highway? Construction sites have heavy radio communication.
I can trigger the PC issue repeatedly when trying to transmit near the 151.8 MHz radio frequency range using a 60W radio.
Docwagon1776
Midwest
Curious: what decision making is done by the vehicle between the pedal and ECM?
Can a PC communicate to any node outside that line of communication?
rick phillips
Norene TN.
360 cid
Don't remember everything exact, it's been over 3 yrs. But my Sprint booster said turn ign. off, remove key or fob from vehicle and place it minimum 50' away form vehicle for 15 min. before installing. During this time the vehicle is checking the electronic systems of the car through the CAN bus system. Also I remember it said somewhere in the instructions, probably first, it said very important to follow instructions exactly.
gilleydog
florence az
2017 ram larami
my went into limp mode sent back to Pedal Commander and no more problems
N2MoPar
Woodland Hills, Ca
If you want a throttle controller, you should check out Bank's Pedal Monster. It doesn't work like most. It plugs into the OBD II port and it works with an app on your phone. Far more tunable and without the problems associated with a throttle interface.
It has much more safety built into it.
Does that sound familiar to anyone.....or did I just pull that thought out of thin air?I
N2MoPar
Woodland Hills, Ca
You're better off getting a Banks Pedal Monster. It connects to the OBD -II port and it has none of the problems that Pedal Commander and others like that have.
It is also much safer too.
ThunderMug95
North Prince George, VA
Ive had mine in since 2018. There is a night and day difference in throttle response. I had mine go into limp mode once…State Trooper beside me on his radio, truck locked into gear and no matter how much pedal was applied, rpms wouldn't change. Pulled over, turned off the PC, reset the CEL and turned PC back on. No issues since. I tried a Pulsar, that thing shut my truck off twice in a week and I sent that back ASAP.
Lyle Longboat
2011 Ram 1500 5.7 Sport CC
Moosonee, ON, CANADA
I have to say, It’s really personal preference when it comes to “if it works” it should be “if it works for you”. This thing takes the pedal lag out for me, I have to keep mine on Sport 2 as the Sport+ is definitely to touchy l. I have 37’s 456 gears and cammed. My truck is totally different when I take it out and when I use it. My 2005 Dodge ram 1500 has one too however I haven’t installed yet as it’s going for safety at some point when I get back home.
I had the red lightening bolt once as I tried to change settings on the fly. Found out you can’t, well can, however the bolt/engine light will come on. Had to pull over restart the engine and it reset. No problems since, that was 2018 I believe.
Thinking of trying the Banks pedal.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
I've never had any problems changing settings on the fly as long as I didn't have the gas pedal pressed. In other words, as long as I was coasting with no pressure on the accelerator. I remember the instructions saying how to change on the fly, although that may have been for the Vitesse throttle controller I had on another truck.
TC Retired
AZ
3.0 ED
I don't have a PC but only stock. On multiple occasions I have felt like the original response was going to cause an accident. I DO want a solution...
rick phillips
Norene TN.
360 cid
No doubt, a controller can malfunction whether OEM or aftermarket. Also been looking for any connection to radio frequency and the controllers. I haven't found the reasoning as the controllers operate by elect. impulses through wires... No doubt anything is possible.
TC Retired
AZ
3.0 ED
If those wires are not shielded completely, then any number of things could inject signal into a system -- Radio station etc...
rick phillips
Norene TN.
360 cid
No clue about how well the wires are shielded, neither OEM or aftermarket. Do know the OEM wires are inside a sheath with a bunch of other wires, possibly those other wires could help shield the OEM controller wires.
turkeybird56
Central Texas
The tk which lost 'control' pulling the Xmas Float in Raleigh, NC. Slow moving, gained speed, couldn't stop. Initial reports were it gained speed. But after watching the video, and aerial video probably just rolling down a grade and picked up speed from the trailer weight. Several of the pickup trucks were modified. Maybe just a blown hose or something(??). Details have been slim. It's a tragedy for all those involved.
If people able to get in front of vehicle and stop vehicle from rolling, IMHO gotta be in neutral, driver panic, did not hit E Brake, but only a thought, will be investigation, or should be. Truck should be impounded, etc.,. Again IMHO.
