Plasti Dip club is here!!
shostopper17
Was it easy to get the front emblem off im gunna spray mine asap
discojables
Phx Az
Suuper easy. Pop the hood and push the clips on the back. Comes right off.
hotcarl
Just found this thread, learned all about plasti-dip, and I am totally going for it. But lemme get this right, it is removeable? If I paint my front bumper which is chrome, I can remove it.
wermbang
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
YEP removable. If you get a good 4-5 coats it peels off pretty easily
quietpeen
2021 TRX
Hellcat
i think that is the beauty of plasti dip.......not permanent
rambob
LA/MS
318 5.2l
Not pretty, but it looks better black. ;). 6 coats
I started getting mild splatter and had to keep cleaning the nozzle.
rambob
LA/MS
318 5.2l
Some may have seen my mishap. Here is the aftermath. The issue, should I plasti over it like it is and let it go or what.
Also, the rear bumper is so rusted. You can kinda still see the small holes and issues. So I will probably rhino it. I thought the rubber texture might hide it. It doesn't lay on as thick as i thought.
Should I do the front bumper rhino instead of plastidip also.
OneShot201
2012 1500 Express - Mineral Gray
Those who've done wheels and other exterior parts, how does it hold up going thru car washes?
I love a good ******** (pun intended) but will often run through a touchless for $5.00 to do a quick cleaning between proper wash and wax.
I want to do my wheels but won't waste my time if it won't hold up to my normal routine.
wermbang
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I have gone through tons of touchless car washes (don't use the ones with the spinny brushes, as they trap dirt in them and scratch like crazy)
OneShot201
That's awesome, thank you wermbang.
I'm gonna pull the trigger on some glossifier too, and try to get a "satin" effect like they show on their website. Ram Heads front and rear are gonna get the same treatment.
That should hold me over until I can get "real" wheels and tires.
DohCanadian
Saskatchewan, Canada
So far i've dipped my grille inserts, 2-way radio whip, factory antenna. Next is the badges and maybe some interior pieces.
twlyons1
Mid Coast, Lincoln County Oregon
6.7 Laramie 4x4 crew 8' dually
Did some more plasti dip today.Did 2 of the wheels.Gonna do the other side tomorrow.I also pd'ed my gas door.What do you guys think,I can't decide if I like that.did my door emblems.I left the red magnum just under the V8 to give it a little different look. Also did these ram head emblems someone gave me.Not sure what they came off.But I am gonna put them to the rear of the back side door above the SLT emblem.
Hay iam in, been usin the stuff for nearly 10 years now and one other thing,,,ilike the birthday cake rims there driver,lololol at least thats what i seen for a split second till i shook my head and said,,,4 of a kind ha ha,,way cool over spray block, never thought of that before,,just may use it...:birgits_tiredcoffee
RYAN66
Denver, CO
5.9 cummins
I'm in!
I use this stuff on my atv parts all the time, it is the best $7:00 you can spend.
plan on doing the wheels first, not sure if I should do the hub cover or leave that chrome and do the rest black.
TheMaddog
DFW
how many cans should i get, just for rims.
Desertwolf
