Plugs, Wires and Dist.
Pennsylvania
5.2 5 Speed
I know about getting the Champion copper plugs, any specific ones though?
How bout some good wires to go with em?
Also want to put on new Dist. cap and rotor, any suggestions?
For 96 5.2
fonzyn75
I went to napa for my dist. cap, rotor, spark plugs, and plug wires, I believe the were made by beldin, another member on her suggested them and they work great. As far as plugs, idk whats the best for them, but i used autolight spark plugs and together all of these components made the truck run alot better. hope this helps
RamBurgundy
V10
Can anyone tell me if I have to use inductive type plugs in my v10. I purchased a 2wd 1995 Ram 3500 recently with the v10 engine. It has not been driven in a few years and one of my first orders of business since driving it home is replacing plugs, wires, air filter, oil, oil filter, etc. I stopped at napa, gave them the specs and they sold me a set of plugs (NGK ZFR5f-11) that clearly states on the package "Resistor Type Spark Plugs". In the service manual I have, it states the following:
"The 3.9L V-6 and 5.2L/5.9L V-8 engines use resistor type spark plugs. The 8.0L V-10 engine uses inductive type spark plugs."
NGK's website says the following when comparing Inductive-Resistor Plugs and Non-Inductive-Resistor type plugs:
"In an Inductive Resistor design, a coiled nickel wire is inserted into the stem and held in place by a spring. The coil acts as an electromagnet, inducing a magnetic field around the center stem, creating a natural “field” resistor. This type of resistor creates around 40ohms of physical resistance, compared to the 1000-5000ohms of resistance in typical monolithic resistor plugs."
I would seem to me that the last line here I bold faced is important. What do I do. I don't want to put these plugs in if they are not meant to be run in this engine (the plugs previous owner had in here were ZFR6F-11). However, NAPA and NGK's site point me to this plug when I tell them what engine I have.
Any help appreciated.
Cheers~
RB
