Portable Tire Inflator
Rado
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
I've got a cheap Chinesium plug-in one my mother-in-law gave me many, many years ago that I keep in the truck all the time.
If I'm going on a longer trip I grab the 20v Dewalt portable pump. It'll air up 4 truck tires from 34psi - 50 psi and 6 (2 spares) trailer tires from the mid 40 psi range to 65 psi on a single battery charge.
I have had the cheapo SLIME models
for years and they work great !
pacofortacos
I have the slime plug in, but just use the Ryobi or Ridgid battery operated ones now.
Travel kit consists of Ridgid Impact Wrench, led light, tire inflator and sockets with 2 4AH batteries in a zippered drill/driver case. Also a bottle jack and 18"x18"x 0.5" carbon fiber piece to place on the ground under the jack.
WY-Dave
Cheyenne, WY
6.7 CTD
Burned up 2 of 3 Slime compressors I can remember.
I have good amount of Ryobi tools so I got this small compressor at first, works great for cars (~36psi) and will get it to 65 but takes a long time
then they have a special going on and I stepped up. Faster to 65, and the best part, you set the pressure you want and it shuts off when it hits it. Working with my bro-in-law moving mobile homes, it takes a bit to get to 80 but it will. The only thing is that it has the screw on connector. The other one has the level lock and IMO, is a better setup. After seeing Badger's post, I located a Slime version at AutoZone
Rado
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
danielmid
Southeast WI
2015 Sport 4x4
I do have a kit but do not know where it is lol.. I really like the one you posted ,, Thanks for the link,, Ill get on for my travel kit
I grabbed an ARB plug kit and threw it in a small orange case marked TIRE STUFF and put it under the rear seat. Threw in some extra plugs, some valve caps, got a few more things on the list like a valve stem tool and a valve stem or two.
Rado
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
I like your storage box :)
I have a couple of the plastic cases as we speak :)
I went to metal cans for my ammo, But now a use for the plastic ones lol Thanks
danielmid
Southeast WI
2015 Sport 4x4
I like this one because it's smaller than the 30 cal size so it fits in the underseat storage very well.
Rado
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
Now those are pretty cool ! And not a bad price either !
Have you been able to use them and see how they work first hand ?
Thanks
I've been using them every week in the summer for the past 5 years,lol.The wife and i drag race the toys,and our local track is 155 miles away,so the jacks get used every week to swap tires at the track on both her Challenger and my truck.I originally bought 1,after using it a couple times,i bought 2 more and 1 is in each of the vehicles.These make tire swaps at the track a piece of cake
I didn't buy the versions with the impact,as they weren't really available when i bought mine,but they claim the impact is good for 420 nm or roughly 310 lb-ft,so it should loosen most wheel nuts pretty easily
MADDOG
Out Exploring Arizona
I air up and down all 4 tires at the same time with the Jeep and it proved to be too much for my VIAIR 400P portable compressor. In fact, it suffered a catastrophic failure with blown apart valves, a scored piston and a trashed cylinder wall.
So, after some review and research I selected a Morrflate TenSix PSI Pro dual cylinder unit. It will air up all 4 of my tires from 15 pounds to 35 pounds in just a little bit over 4 minutes. I built my own 4-way inflate/deflate system.
Rado
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
Your inflate/deflate system you made is it the hose with a valve ? Thanks
Rado
Rado
US NAVY VETERAN
Maine
Pentastar 3.6 V6
Well you just are going to make me spend more $$$$ on my RAM now lol
I just like a good travel kit !
Just had a new differential put in a E Brake cable and a couple other things and that nailed my 6k$ :O ,so letting cash catch up
Had a couple errors w/the TPMS so going to order 4 sensors from Benny !
Got to have my toys and tools lol
Had a couple errors w/the TPMS so going to order 4 sensors from Benny ! Got to have my toys and tools lol
You can never have too many tools :waytogo: :Big Laugh:
I even use the 12 volt jacks at home,instead of dragging out one of my floor jacks,lol.
jawzs2
South Jersey
