Possessed 2012
carpy1166
US
Greetings all,
I just recently purchased my 2012 Ram sport. I have had some crazy crap going on and I can't seem to get it figured out. While the truck is running, the warning chimes will start sounding off, warning lights will begin to flash, stereo will go off and then back on by itself, front windows and mirrors will stop working, trans light, oil light, brake lights, service 4x4, service traction control, service engine and multiple other warnings will flash. The truck will begin to run rough and feel as if I am dropping it from drive into 1st gear as I'm driving. I will shut the truck off and let it sit for a few minutes, and it will be fine, then begin all the same symptoms again. Has anyone else experienced anything like this? Please help!!!
Thanks
MADDOG
Living in a Firepit
I've seen this happen on some trucks and cars that have a bad battery. Why it's bad is part of the diagnosis but what I would do is pull the battery and get it load tested.
If it checks out, make sure you main power grounds are well connected and clean.
Lastly, if the power ground is in good shape it could be a control module.
Good luck!
