Powder coated headers
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
I'm looking at the Pacesetter longtube headers, but the are powder coater. I've had headers with this same powder coat and it just burns off and then rust forms, wat can I do to prevent this from happening if I buy these??
Droid incredible 2 on the move!
quietpeen
2021 TRX
Hellcat
thats a good question. I'm sure someone will chime in who knows for sure.
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Ok kool never thought about wrapping them... But do I need to strip off the original powder coating first before wrapping? And how many feet should I use?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
You need them ceramic coated not powder coated. Wraps attact moisture in a DD, works good for track setups but a DD is gonna see rain.
txbass06
NE Texas
5.9 Magnum
^^ beat me too it about the fiberglass wrap. They'll hold moisture and cause your exhaust to rust prematurely
Sent from my iPhone 4 using Tapatalk
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Yeah the wrap is good for a straight up race setup that gets trailered in an inclosed and stays in a garage.
ramin44s
4.7 v8
ceramic coated and stainless headers are the way to go from what i have seen
blackout11
alpharetts GA
2011 R/T
Had ceramic coated headers and had them wrapped to and also had wrapped shorty headers on my d/d mustang and had no rust problems not like i went running 90 mph through puddles.
OlDirtyJohn
Naha-shi, Okinawa, Japan
2004 Quad Cab 2500 *Sold*
header wraps also cause pretty bad pitting of the metal. ceramic coating is the way to go, both inside and out.
BMRbrnSNRbrd
Norman, OK
2010 Dodge Ram 1500 CC Hemi Sport
Definitely do not do a wrap..buddy did it on some headers and they lasted a year before they started to rust badly.
I know a lot of people do ceramic coating but it's quite expensive. I got a set of used Doug Thorley headers for my '04 and they were a little rough. I cleaned them up with sandpaper (surface rust) and then cleaned them with mineral spirits. After that I rinsed them with water, dried them, and then used VHT header paint. They still looked perfect after two years when I traded the truck in. It's a nice, easy, and cheap alternative.
truckin151
2013 sport
Yep agree with everyone so far, get them ceramic coated, NO header wrap. On top of all the previously posted info, most wraps will void any manufacturer warranties that come with the part. So if the crack from the pitting rust prematurely etc you wont be able to return them or get anything back.
truckin151
2013 sport
Ceramic coating isn't to bad, about $150 for a set through jethot.
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
I'll see if I have a shop here in Tallahassee that does coatings, if not ill do it myself, it'll be a good DIY project
BMRbrnSNRbrd
Norman, OK
Don't get me wrong, the way I did it will not keep heat in like ceramic, but it worked great for me.
swamp_life hemi 05
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Wat if I go with the bbk shorties? I think they're stainless? BBK Shorty Headers Chrome NIB PN # 4009 here is the model, wat do you guys think about them?
OlDirtyJohn
well they arent JBAs, but they are still pretty nice from what ive heard. wish they were available for the 2500s
joshhhh
