fxnytro17
- Feb 7, 2013
- 88
- 39
- 2013 Ram 1500 Sport 4x4
- 5.7
Figured I’d share,
2013 ram 3500 longhorn, only owned 4 moths
Recently lost power to my memory seat. Figured for sure it was memory module as the power pedals were gone as well
Test light was nice and bright on the power to the modules and motors.. so it was suggested to use a light bulb, which I did and instantly lost power. Showed 13v on mulitimeter but even test light wouldn’t glow.
Traced wires and figured I’d go right to the main connector. Here you go, there was two B+ connectors just about corroded off.
Ps. I have a 1500 as well that had previous Tipm problems, I’ve been using the pins out of older rams to re pin these as the connectors are different but pins are identical.
This site also needs some updated wiring/schematics.
This did help along the the connector pin out I found. It’s just hard finding the connectors .
A L L Diagnostic Trouble Codes ( DTC ) — 2013 Dodge and Ram RAM 1500 Truck 2WD V8-4.7L Service Manual | Operation CHARM
Detailed repair manual for the 2013 Dodge and Ram RAM 1500 Truck 2WD V8-4.7L.
charm.li
