power wire?
BLKDODGE04
Wataga, Illinois
4.7 Magnum
anyone tried the power wire on the 4.7 and noticed any difference? i tried the homemade version with soldering the 4.7k ohm resistor in line of the iat sensor wire and i didnt notice any difference.
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
I ran one for 4-5 years but it was mostly to compensate for running long tubes.
Took it off when i added a 180 t-stat.
EDIT: oops sorry i did not realize you were looking for 4.7 owner experiences.
HemiBabe
DFW
Bump for ya, I'm sure there will be a difference, but prolly nothing you'll feel by "seat of the pants"
HemiBabe
DFW
Found this:
They give an extra boost at wot, and ''supposedly mpg's ,
It shows a lower air temperature than what is actually being sucked into the motor,making the pcm admit 2% more fuel than normal. It does not hurt the motor in anyway and can be removed for epa testing.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I was one of the guys that first tested the power wire when it came out. It tricks your computer into thinking that the air coming into your engine is 20* coller than what it is actually reading. This causes the computer to feed your engine a little more fuel. I tested this at the track and on the dyno and never saw a positive or negative gain from it. Only thing that changed was that my mileage actually went down instead of up.
BLKDODGE04
BLKDODGE04
Wataga, Illinois
4.7 Magnum
thanks for the info, like i said i tried it and never noticed any power gains or fuel mileage change
savannah996
Ok, so you "trick" the computer by changing the perceived air temp. The computer has a table for fuel requirements at given temps, and adds a few percent more fuel. What stops the o2 sensors from reading the rich mixture and compensating by shorter fuel injector cycle rates?
2003MOPAR
NORCAL
BS
The most notable change I noticed in my 4.7 was the aFe followed by the Super Chip program. I never look at MPG. Ever. Throttle response and acceleration is what I wanted. I got it. I dump 93 octane in the tank and roll away. I'm a happy camper.
joshhhh
