Problem with drivers side headlights
Yankeefn65
Chesapeake
2023 big hornHem
I have 2023 Bighorn. My drivers side headlight won’t come on. I removed bulb to fix moisture and now won’t come back on. Checked all fuses. I have checked everything and nothing seems to work. No mater what I search can’t find if relay is bad. I think plug may be bad did check on it power there then drops.
I need some advice
1stindoor
NC
'23 2500 MegaCab
I had an issue with my left rear taillight that kept "going out." I unplugged it and filled both sides of the plug with headlight grease. Haven't had an issue since. Worth a try.
