Project turn signal
Syke001
I recently updated my headlights from regular halogen to projector LED and turn signal does not flash on either side during the day with the headlights off and does flash with the headlights on at night no error codes either time no hyper flash with resistor any idea on how to fix?
diymirage
Banned
Sounds like a wiring issue to me, Iether the turn signals are drawing power from the headlights, or (And I think this is more likely) it is somehow grounding out through the headlight
RamDiver
Marlborough, Ontario Canada
2021 DS
Did you add aftermarket headlight housings that also contain turn signals?
If yes, have you tried contacting the vendor?
They may have experience in resolving issues related to their products.
Posting a link to the headlight housings used would be helpful, even better if you have a schematic drawing or other technical info to share.
S
Syke001
You think I installed the resister in the wrong place would that be a cause?
diymirage
Banned
There's a resistor there?
What does it do?
Or, what should it do?
I mean, think about it, they work as the should when the headlights are on, but not when they are off...that means the issue has the be related to the headlight AND the indicator wiring
Yeah I would double check that resistor
BossHogg
Navy Badge Law Enforcement
Oakland Township, Michigan
6.7L Cummins
It is difficult and dangerous to offer an answer simply because you have not provided much information. RAM introduced a new electrical architecture in 2013. Knowing the trim level you have, the brand/model of the aftermarket headlamp you are using, and exactly how you wired the assembly would be helpful.
