puck vs shark fin
ramlife68
need a little help clearing my garage with my 2018 2500 cummins...thinking of changing the shark fin to a puck....anyone else do this....dont care about connect ,,just want my sirius (and I don't have nav anyway)
thanks guys
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
There are a few threads on site , From what I remember (I'm A Old Fart :O so do not remember alot lol ) The puck works ok but you will loose or get low reception in some areas ! I am sure the gear heads will chime in with better info ! Please Update what you do find out and how it works
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
FYI, there are also 2 mounting styles depending on where the antenna is on the roof... Front Cab mounted has more curve vs rear cab mounted is nearly flat.
Contact forum vendor @AllMoparParts.com and he (Benny) may be able to id the PN you need.
M² Mods.
Lawsuit11
Westland, MI
thanks guys
With the connect problem. I have ordered just an fakra connector and a cellar antenna to put in the dash to see if it works instead of me upgrading to the shark fin and having to pull the whole head liner down. Might be an option for you if you downgrade and want to keep your uconnect services. I will let you know what my outcome is with using a separate cellular antenna.
—2018 Ram 1500—
Badger 13
North Idaho
2013 Dodge Ram 1500
I believe that the shark fin antenna is designed for dual use, satellite radio and GPS, where the flat one's are "single" use.
R
ramlife68
excellent ,,,great info....and yes i would like to keep connect if possible
R
ramlife68
thanks mine is front cab mount
kad
Hudson Valley, NY
5.7L HEMI
The puck antenna is GPS & XM (satellite radio). The shark fin is GPS, XM (satellite radio) & Cellular (Uconnect).
-K
kad
Hudson Valley, NY
5.7L HEMI
I'm interested to hear how this work out. I tried it with a cheap eBay antenna and it did not work at all.
-K
Lawsuit11
Westland, MI
-K
Yeah. I’m just waiting on it to come in the mail. Might be a waste of $10 but o well. Lol
—2018 Ram 1500—
R
ramlife68
OEM is 50.00 i think but don't want any leaks.....antenna has its own seal but do you think adding silicone or something would be a good idea?
Lawsuit11
Westland, MI
OEM is $50 just for the antenna, then you have to buy a jumper harness and the body harness if you are upgrading to the shark fin. And then pull down the headliner so you can route the new body harness. If you’re down grading all you have to do is switch out the antenna but a lot have reported leaks. Yes it has its own seal but from this forum it doesn’t give a good seal.
—2018 Ram 1500—
R
ramlife68
hmmm you wonder why it would leak more than the shark fin??? anyone have a fix for this after downgrading to the puck?
Lawsuit11
Westland, MI
-K
Have an update got the 2 pcs in to make the antenna. All you have to do is connect the two together and plug it into your radio. I just set my antenna behind the radio and it’s getting decent reception. The area I live in is a slight dead zone at least for my phone but this antenna picks up the signal very well. I call Uconnect with the assist button on the mirror and talked to someone briefly just to make sure it worked. Lol. The link below is what I ordered off of eBay. Took about 15 days to arrive but working good so far
Few pictures with proof of good signal even LTE
Below link is what I ordered on eBay
https://www.ebay.com/itm/Car-Telema...tail-6-quot-/173907959230?txnId=2017137898007
https://www.ebay.com/itm/4G-LTE-GSM...gnal-Booster-/382924673276?txnId=982830333025
One side of the antenna has double sided sticky tape and the wire is about 9ft(3 meters) so you could run it about anywhere
—2018 Ram 1500—
kad
Hudson Valley, NY
5.7L HEMI
—2018 Ram 1500—
Interesting. That antenna looks pretty much just like the one I got, except the one I got had the Fakra-D connector on it directly and was listed as a 3G antenna. The other difference is that I have an RA4 radio as opposed to the UAx type that you appear have. I'm pretty certain that the RA3/4 is a 2G or 3G connection unlike the 4G connection on the UAS/Q radios. I might give it another shot with the one you got and see if it works any better. If I do, I'll post the results.
-K
Lawsuit11
Westland, MI
-K
Yeah I do have a UAQ lol. Worth a try. Now I have free WiFi for the time being lol
—2018 Ram 1500—
R
ramlife68
no leaks? when changing to the puck....or did you silicone?
alphaprojects
