Put 37” tires on stock Power Wagon
AngryPills
Cali
I recently put 37" and I will go back to 35" once the tires are done. You give up way too much in articulation and everyday drivability. If you are willing to do 37" right with proper $5K suspension upgrades then it looks and works great. I have nearly 300K on my 2019 power wagon and I had 35" on it most of its life went to 37" just for a quick test and I can tell you its too much for stock power wagon with 6.4 Hemi. You can talk yourself into it being "good" but its really won't function well just look really good.
buckeyexx
Ohio
2016 Power Wagon
Wow! That’s is impressive and great to hear. 300k on a 6.4 and it being only a 2019.
Docwagon1776
Midwest
He was probably still driving when he posted that. :D
I don't think I've put 300k on all my vehicles combined in the past 15 years!
62Blazer
Midwest
In regards to different wheels, there is a fine line. The stock wheels have a lot of offset, meaning they set narrow or in close to the vehicle. This helps prevent the front tires from rubbing on the back of the front wheelwells when turning (which is the most common/worst rub point). However at some point in time the tires will start rubbing on control arms and other suspension parts when turning as the tires get bigger. Aftermarket wheels have less offset, and it varies quite a bit by type and brand, meaning they will sit out wider or further away from the body (tires will stick out more). This helps prevent rubbing on the suspension but will cause more rubbing on the back of the front fenderwell when turning.
You don't need $5k in suspension upgrades to run 37's. Some people do it stock or get a small leveling/lift kit for the front. I personally have 1.5" Thuren front coils and Fox shocks on mine with 37's and think it does fine. I also think gearing and power with 37's on stock axle gears is adequate. Sure, the 37's put more "stress" on everything but not like it's going to explode or fall apart in 5,000 miles. If you want to put 300k miles on it there probably is a difference and would stay with small tires.
4xdad
Edmonton Alberta
2015 powerwagon
I’m sure there are a few ways to do this. If guess it depends on what you want to do and how much money you have how you use your truck and your wallet will determine what you end up with
Corvette427
Corvette427
PA
Why is everybody so obsessed with a leveling kit. I like the look of a slightly raked pickup. I put 35's on my RAM. I'll change my profile pic soon
You know it’s funny you say that. I was looking at my truck last night thinking, I really don’t mind the way it sits now.
2003F350
6.7 CTD
I have seen a LOT of trucks with a LOT of rake to them (particularly half tons or 2WD HD trucks) and they look...wrong. My wife's F150 DESPERATELY needed its leveling kit when we bought the truck.
But the Wagon, even stock? Looks just about perfect without a level.
