Put my illicit cut relocation bracket in today
jrhodes
munford, tn
So I made another order from moes last week, my illicet cut brackets came in and the hellwig sway bar and the air bags. Couldn’t be more pleased with the change it gave my Mcgaughy 2/4 kit. No more vibration or squirrely rear end. Bags helped the rough ride with all the bad roads. Now just waiting on my ARH long tubes and y pipe. After cutting 1 coil out of the rear coils I only lost 1/2 inch. Might have to cut one more to get level. On an added not the guys at moes are some of the best in customer service I’ve ever seen.
circuitguy
Elk Grove, CA
2017 Ram Tradesman Regular Cab
5.7L HEMI
Your truck look great! Everything you have done works great together, that truck belongs here in Cali! If you get a chance could I get the part number for the air bags you used? I have the same truck and the same lowering kit and I also took one coil off each spring in the rear, had to close that gap a bit. Your right though maybe one more or a half a coil would do the trick but not a have to do. What were all the ride problems you were having? Right now I tend to bottom out here and there in the rear, it gets squirrely under hard acceleration and any speed above 70 and I have no idea where the rear squeaking noise is coming from.
abouttobeglue
Truck looks sweet, digging the wheels and im not usually a shiny wheel fan
jrhodes
jrhodes
munford, tn
I h
I had a rear vibration that made me think a sling a wheel weight especially at 65-70. The rear end was tail happy to say the least and the pot holes here made me feel like it was a log wagon. The decision to do the cut brackets was because when I talked to the guys at moes he said if you go any lower that a 4in in the rear the upper control arm mount will hit the frame. Also I removed the bump stops that came with the mcgaughy kit. The air bags keep it from bottoming out. They also let me raise the rear I’ve i need to for a heavy load. Finally the sway bar really help the body roll since my truck didn’t have one. Thanks for the compliments I love these trucks there are so many ways to put your own cool on them. Your looks cool as well. Qa1 shocks are next here and then look out I’m gonna void that factory drivetrain warranty
circuitguy
Elk Grove, CA
5.7L HEMI
I h
How long did the install on the "cut brackets" take? Were they easy to set up? Can it be done without removing the rear axle?
jrhodes
jrhodes
munford, tn
I was the air lift 1000 for lowered trucks from moes performance
jrhodes
jrhodes
munford, tn
It took me 3hrs only because my plasma cutter crapped on me. Lots of cutoff wheels and unibits I used a reamer after the small unibit and it worked out fine. You are cutting the entire upper control arm mount off and it is made of thick steal. Patients is your friend. I did not remove the rear end but I did lower it as far as I could without having to disconnect brake lines. I did take the brackets that hold the line to the frame loose for more clearance
circuitguy
Elk Grove, CA
5.7L HEMI
Thanks for the info it will really help me out. I don't mind taking all apart and hanging the axle on stands but I would rather not disconnect the brake lines.
Pull the diff cover,pop the axles out ,unbolt the backing plates from diff,and leave the brakes and backing plates attached to the truck is the easiest way to pull the rearend out . I've done a few Illicit brackets now,and it's definitely easier to do with the housing out from under the truck.Also a good time to change diff fluid.If you don't have access to a cutting torch or plasma cutter,go rent one.You can't make all the cuts you need with a cut-off disc,there's a couple cuts that are virtually impossible to make with a cut-off disc.
Simpsj2
Looking for install instructions for illicit cut brackets. Rather not wing it if i dont have to.
Jems007
