Quad or Crew Cab
Rex1974
Utah
I recently bought a 2010 Ram and I need the model in order to get the correct step bar. I am attaching picture with Dodge RAM specifications.
I would appreciate your help !
Thanks in advance
BWL
Embrace the skeptisism
BC Canada
It says laramie quad and crew cab so post a pic and we'll tell you what it is. Based on what I see its probably quad.
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
Im gonna go out on a limb here and assume the guy has a quad cab.
But it’s real simple OP;
Top pic is a crew cab. Bottom pic is a quad cab. Which one does yours look like?
turkeybird56
Central Texas
DITTO to cornelius..............
corneileous
Podunkyville, OK
One thing I am 99% sure of, you don't have a regular cab.
Random_Walk
...what's this bolt do? *plink* ...oh.
Out
2017 QC 4WD SLT
Pentastar 3.6
And thankfully, not a neutered cab-and-a-third like Ford once offered!
TXCOMT
Oh, Lord... the SuperCab. Had one of those... the back seat was worse than worthless once the kids got old enough for kindergarden. :/
MJCs18Diesel
Rochester NY
Diesel
I had the same problem. FCA calls my '18 BigHorn a crew cab. Vent Shade calls my '18 a crew cab "with installed tool storage floor". I initially bought the wrong window vent shades AND composite side step. I discovered the side step problem AFTER I had mounted the brackets and undercoated them. Fortunately, Amazon let me purchase the right one; and, they let me swap out the brackets, and I had to make sure I glued the correct Part-number sticker on the returned box. And, they sent me a "free" shipping label, and they let me send the wrong one back, all for a complete refund. I even called Lund to explain how my '18 is is not clearly described in the part numbers on their and the Amazon web site. Lund also helped me to make sure I ordered the correct P/N.
Tracy in IL
Moline IL
3.0 diesel
at least for the 2017 year, only way to get the longest beds to get the Quad Cab. Dealer found out only way to get crew cab and longest bed was to order a Commercial truck, which I ended up getting, completely pleased with it. If an adult is going to sit in the back seat, crew cab is the only way to go.
BWL
BC Canada
Whats the longest bed?
BWL
BC Canada
Should be just the 6-4 bed to my knowledge. I think the 8 foot bed is only on single cabs.
That was my thinking as well and if so he received incorrect info as I have a limited crew with 6.5 box, bit there is a possibility he went with a chassis and cab and mounted an 8' so I felt the need to ask.
BWL
BC Canada
Since the chassis and cab don't come in 1500 maybe he means a ram hd, but I know they come in crew cab 8' box so I am now confused.
