Question for 3” lift (fab tech) and diff lowering
Dano86
South Dakota
2019 ram 1500 and looking at fab tech 3” ball joint UCA lift kit (K3167M). I was also looking at the ready lift 3.5” but found some comments about not being for off-road use. I am not doing anything serious but forest service roads and pastures can get rough. Any recommendations on diff lowering? I keep pickups many years and don’t want to stress the 4wd so I want to do it right.
Also, why can’t the OWM rims be used?
crazykid1994
Up to 3” on the trucks no need to diff drop. If you want a diff drop kit go up to a 6” kit. Ready lift is a mall crawler/street queen lift kit. Leveling struts would be your best friend. Ie: fox, bilstein, eibach, fabtech, king, rancho. If you plan on running above 2” make sure to install angle correcting upper control arms to help keep the alignment better. Bds sells a kit for your truck as well and uses fox shocks
D
Dano86
South Dakota
Thank you for the info! If I am understanding correctly the fab tech 3” I am looking at looks like it comes with angled UCA. That essentially takes care of the small diff correction that would be needed?
ThunderMug95
North Prince George, VA
Negative. Thats not going to have anything to do with CV shaft angles. Just helps articulation of the upper ball joint. Diff/CV are a different animal.
D
Dano86
South Dakota
Okay. So do I need to worry about dropping the diff/cv somehow so they are not stressed and wear out prematurely?
crazykid1994
No. You will not need to worry too much about that. And the upper control arm is just for better suspension travel and better alignment specs
D
Dano86
South Dakota
Great thanks. Do you know why they say OEM wheels won’t work? Is it rubbing? If so can that be solved with a 1/4” spacer?
crazykid1994
More than likely a larger wider tire will rub the upper control arm. You could email fab tech if that’s who you go with
Bds kits
ThunderMug95
I ran into this very issue with tbe Zone UCA’s. My tires are 12.5” wide. I have about 3-4mm gap between uca and inner sidewall. I love my wheels and they are out of production now, so no chance of finding them in -18 is very slim. Im solving the problem with Bora 1.5” hubcentric spacers.
D
Dano86
South Dakota
I don’t like spacers but that may be my temporary answer. Do you know what size can be used without needing to change out the studs?
ThunderMug95
It really depends if your wheels have pockets on the back of them. Mine do. I believe with a 1.5”/38mm like I ordered the studs would stick out 1/8”.
D
Dano86
South Dakota
I plan on keeping stock 18” wheels. I need to take one off and verify but I read the backspace is 5.25 so I will only need 0.25” spacer.
ThunderMug95
I want to say some of the stock wheels have a pocket. I cant say for sure. Mine came with the 17’s and I shucked them pretty quick.
D
Dano86
South Dakota
For those fallowing or that look it up later. I ended up going with the rancho quick lift. It leveled the front and added 2”. Was supposed to be a 1.5” gain but ended up being 2 when measured from the ground to the bottom of the fender well opening. Instal wasn’t bad. If you have knowledge on disassembling and reassembling front ends, you can skip a handful of the steps in the instructions. I did and wasn’t a problem.
Orca
