Question from you Experienced Ram Drivers
CanRebel
Toronto
Going to start off say, I'm using to driving my car and/or sometimes F150
I'm not sure if it's just me not use to how this Truck handles yet.
Rebel has air suspension, which I've never had on Truck before.
I put it to Aero Mode and also tried with Normal mode.
Truck seems bouncy. Can feel it in steering wheel, and also Truck. It's not lot, but I seem to have keep
correcting it. I am driving on a highway, it's also at times bit windy, not major though.
Is this 'normal' or just me? Seems to sway a lot. Truck is empty.
Advice?
chopperman1
Peoples Republic of Massachusetts
2018 Rebel
5.7L HEMI
How is your tire pressure? Assuming the 2021's are the same as my 18' is 55 front, 45 rear. They will tend to bounce a bit if too low. I've has 2 Rebel's (16 & 18) both with 4 corner air, they definitely ride a bit different than my previous truck which was a 2011 1500 Big Horn.
CanRebel
CanRebel
Toronto
It says on console. tire pressure is 4.2 for all tires
CanRebel
CanRebel
Toronto
I installed the Uconnect app. It sent me an email.
The app says 441 Left Front, 353 Right Front
Left Rear 448, Right Rear 448
Need to fix Right Front.
Then I guess I'll try to lower back little bit, and both front.
I ordered Hellwig Sway bar, which should be here tomorrow.
Adding that, does that effect what I should do with tire pressure?
CanRebel
CanRebel
Toronto
I put all tires to 52 PSI/359 I noticed a huge difference just test driving on street, haven't tried highway yet.
Before, I would press gas, tires would spin bit. Now when I do it, the Truck moves like it has a Hemi.
Sorta of expected I guess. I need to purchase set of rims and tires when I'm driving to work. Keep these ones for fun.
Depending how this feels. I might try 55 in front and 50 in back. Test it again.
CanRebel
CanRebel
Toronto
Just doing 52 on all of them, driving on highway. Huge difference.
I will taking both your advices, and doing 50 front/45 rear.
You put 20" wheels? What do you go with? Did you have mod things?
I seen someone mention they put these on a Rebel, stock with no mods or spaces.
Cooper Discoverer AT3 XLT
Only 18" but reviews seem good.
Going be winter in few months. So need to pick something that will work for that.
PaleFlyer
Charlotte NC
'18 Rebel door panel sticker (What I always use to set my tire pressure on all vehicles) is 55/45, rides great, no "bounce".
Crawgator59
Baton Rouge
Piece of advice get rid of the air suspension. It’s not a question if, but when it will go out. Mine last December and was fixed under warranty. Just went out again out of warranty. Replaced system with 2” coil over lift kit. Even had it been still under warranty, I still would have replaced it. 2017 Rebel here.
rule18
Admin
NY
2017 Rebel
My 2017 Rebel has the four corner air. E rated front tires at 55 (cold) and rear at 45 (cold) and it rides and handles great.
PaleFlyer
Charlotte NC
Did the shop not have some kind of parts/labor warranty on the work??? Seems like under a year should be a shop issue...
Crawgator59
Baton Rouge
Maybe, but I already had in my mind to get rid of the air ride. After 2 breakdowns not reliable enough for me. The last time I was pulling my 24’ bay boat. Luckily I was only 15 minutes from my camp. Not gonna take a chance again. Plus the dealership had for 2 weeks the first time.
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
You're right of course, eventually air suspension will have issues. But, the design of the air suspension on 5th gens seems to be a lot better than it was on 4th gens. When I owned a 2017 Rebel I was constantly reading about failures with the air suspension. And is part of the reason I got rid of that truck. Since the 5th gens have been out I've only seen a couple of issues with the system. Air suspension is a must have for us. The wife loves the entry/exit mode, and I like to raise it all the way and deploy the side steps to help reduce door dings when I park in crowded parking lots.
KAKA
