Question on Winch
CoreyLRam96
I've been wondering for a while now if a 1996 Ram 1500 would look good with a Front bumper winch, it's a 2WD so that is what has been preventing me from buying it just because I know it's more for looks then actually pulling someone out of mud. Anyways, would you guys care to give your opinion on if I should get one or not? All feed back is appreciated! :naughty:
MANual_puller
Shade tree grease monkey
Vinton, Iowa
2011 Moose
5.7L hemi
A good winch can make a 2wd more capable than a 4wd pending there are trees around. It's also handy to not have to carry a chain or tow strap in the event of a sticky situation ;)
Johnn123
Ontario
2wd with a winch can actually get around really well with the right set-up! Just remember to get one with a working load limit twice that of truck IIRC.
BBartow
New Port Richey, Florida
5.9L Magnum
Whatever your truck weighs loaded x 1.5 is the minimum. Doesn't hurt to go bigger because you only get the full power on the last layer of line.
MANual_puller
Vinton, Iowa
2011 Moose
5.7L hemi
You mean first layer, right? Last layer is most speed and least power. I recommend going with 12,000 lb for gas truck. Stuff doesn't get as hot if you run it at a lower % of capacity. Typically cooler operation with electrical equals better longevity.
BBartow
5.9L Magnum
I meant last layer on the drum if you were to spool out :p
joshhhh
