RA1 to RA2 need a microphone option
R.L.K.
Bristol , Tn.
Looking through AllMoparParts.com there is only one upper cover available, the one I have listed. With 3 lowers available, so I believe this is the one I need.
Part Number:1YW14DX9AC
Part:LOWER COVER
Replaces:1YW14DX9AB
Part Notes:W/MICROPHONE, W/SMARTBEAM
I'll dig through my receipts and get you an answer Sir , it may be tomorrow befor I can though ...
Cesar592
3.6 pentastar
Microphone ra2
hello sorry if you could connect the microphone was only plug and play I'm buying one since I have a 5.0 radio but I do not have a microphone and I've found one for 130 but I need to know if it actually works
crazykid1994
Somewhere it's documented what the overhead mic is from the 2017 trucks instead of the mirror
Cesar592
3.6 pentastar
Ram 1500 slt 2013
Microphone uconnect 5.0 install
R.L.K.
Bristol , Tn.
The OEM mirror with microphones & the harness is plug n play .
OEM MIRROR WITH MICROPHONES 911/ASSIST
P/N 68096091AF
MIRROR HEADER HARNESS OEM P/N 68207372A
Sent from my SM-G900V using Tapatalk
Cesar592
3.6 pentastar
Microphone install
you can upload photos of the installation to see how it works and the assist and 911
Cesar592
3.6 pentastar
Ra2
Cesar592
3.6 pentastar
I do not understand what you mean when it's documented
R.L.K.
Bristol , Tn.
He means the information has been posted here before .
I read some literature on the 2017 mic can't remember where but I'm pretty sure it was somewhere in 4th gen audio threads ?
If I see it again I'll post a link to it here Sir .
DeereGuy
Preferred Vendor
Pittsburgh, PA
Here is the 2017 mic info with pictures. You would have to cut the headliner and create a harness. There is one on the driver and passenger side.
R.L.K.
Bristol , Tn.
Could M2Mods make a harness ?
Not for me , just asking for this thread
No_bogies
Check with www.allmoparparts.com
I think they have an option
If you want the audio controls on your steering wheel allmoparparts.com has that kit as well and there is a very good post on here for the how to install the audio cotrols and hands free phone button on your steering wheel ! Hope this helps ...
That sounds like the better option
Sent from my XT1254 using Tapatalk
lbrou87
Louisiana
I know this is a old thread, but I felt it is better to respond here than making a separate thread about essentially the same thing.
I just bought a 2014 Ram 1500 and is almost ready to do the RA1 to RA2 swap. I'm also thinking of getting the mirror and harness setup--or the Amazon mic route if that would be easier. The only thing that is stopping me is the location of the harness to plug the mic/mirror. Is it on the end of the passenger side dash near the far right AC vent? if so, how do I take that part of the dash off to reach it? I've searched for this on the internet and didn't find an answer.
R.L.K.
Bristol , Tn.
It's best imo to remove the glove box , then with one hand from the backside and one from the front you can remove the A/C vent pretty easy [emoji106]
Jeff Loven
6.7L Cummins
Ok, I want to also add a mic to my 2014 RAM 5500 Cab / Chassis. I upgraded a couple of weeks ago to a RA2 radio and everything works fine. I took the glove box out and looked behind the passenger AC vent, and there isn't a wiring harness / plug. I assume I would have to run wires from the rear view mirror (mic location) to the radio?? If so, can anyone supply a wiring diagram? I tried the link on page 2 but it no longer works and the pic is to small to read clearly.
I found a mic like this one http://smile.amazon.com/gp/product/B00DN72KZU?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
on eBay for $50 and got it. I plan on just wiring it to the rear plug of the radio if I can get fortunate enough to find a wiring schematic. Thanks for any help.
