Ram 2500 Dual Shock Hoop?
DrKelly301
Hello, I'm new here! I picked up a 2014 Ram 2500 long bed 5.7 hemi really cheap and I want to have some fun with it. I really enjoy the look of the dual shock hoops with fox gas shocks w/ separate reservoir. I want a decent lift out of it, it is currently stock and I like the bulldog/pre runner look. What are some good recommendations on lifts/hoops for on highway as well as off road? I drive dirt roads for work and travel highway across state frequently.
sbuko213
Arcadia, FL
6.7 HO
Carli and Thuren make some nice lifts for the diesels. They should still fit your truck but the front may be stiffer due to the lighter motor you have.
sbuko213
Arcadia, FL
6.7 HO
Also you may want to look into Pure Performance. They make some really sick kits for all of the Rams.
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
Pure Performance or BDS will probably be your best bet for a Hemi truck. Just keep in mind that unless the shocks are valved properly to be in a dual setup they will make your ride stiffer.
