RAM Configurator
Dargo72
NJ
N/A
Good Day,
I am playing around with the online configurator on the RAM website and having an issue. I am building a Limited and want to have the upgraded speaker system. However, I do not want the tow mirrors. I am having trouble finding the way to basically get almost every option except being forced into getting the tow mirrors. I played around previously and was able to get everything, except tow mirrors, before and am unsure if I am doing something wrong (most likely). I do intend to get the brake controller, just not tow mirrors. Any wisdom is appreciated.
Thank you,
dsps70
Fredericksburg
HemiV8
Good Day,
Thank you,
The Ram online configurator is very buggy. Sometimes you’re able to configure the vehicle the way you want, the next day you cannot. Try selecting the Trailer Brake Controller when your configuring your Limited, which is a separate selection from the Tow package. This will allow you to bypass the Tow package with the tow mirrors. Select the Brake controller first before u add any packages or groups.
D
Dargo72
NJ
N/A
Yes, I'm going to try again as I was able to do everything the other month with no issues.
Thanks!
joshhhh
