Jahaa
Hello, So after my truck was parked for about 1 week i went to start it and was unable to because i got a "Service Transmission Continue in D. Do Not Shift or Turn Engine Off" message on screen. and all the lights on the electronic shifter was just blinking. So i grabbed my computer and scanned it. Got 2 codes from the shifter. U11C3 + U0101.
After this i checked all the fuses i could find and no problem. Then i decided to buy a used Gearshift switch. My original in the car had Part number : 68171965AH and the one i found used had 56054275AH. But after some research online it seems like it should fit my car. So i swapped the them around and still the exact same problem and exact same fault codes.
Now i have no clue what to do. Could it still be a problem with the Gearshift switch? Is the used one i bought faulty or does it not just match my car?
Any ideas would help.
Thanks in advance.
Thanks in advance.
