Ram drivers window and seat question
Alpinestars96
New member here! When I roll down my drivers window it rolls down off track, I found the bracket that hooks to the window and the regulator frame slips off the bottom of the Window how should i fix this? Also can I add a manual moving front drivers set to a frame rail for a power seat? Thanks!
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
I would think you could remove everything off the donor non-power seat, and and if it the same year and model truck, everything will bolt up to make it then power, I dont know if it has power tilt or recline, that may not work. make sure you use an extended cab seat with extended cab, and single cab seat with single cab.
as for you window issue I've fixed off track windows, but dont know hwo to explain maybe another member? best of luck
