Ram Quad Headlight+Fog Light LED Bundle
Status
Not open for further replies.
WhiteNBlackRam
Southern California
Low Beam- Headlight Revolution Supernova V4 With decoders. No errors. Everything fits underneath dust over perfectly.
High Beam- Nineo . Fits perfectly underneath dustcover
Turn Signal- Diode Dynamics switchback with plug and play harness. No cutting required. Just mount resistor and plug into original wiring.
Fog Lights- Techmax. Will include canbus decoders. I didn’t require them.
Trying to sell everything together. Everything was plug and play for my vehicle with no error codes. Came off a 2014 Ram 1500. Used the website bulb facts to try and find the brightest setup. Asking $225 shipped.Through PayPal F&F. Basically Brand New. Only used a couple months and rarely did any night driving.
Pneed38
[emoji848] Would it all work with a 2016 Ram 1500 Express with stock halogens?
WhiteNBlackRam
WhiteNBlackRam
Southern California
They use the same bulbs, so I don't see why not. All I was able to find was that they probably wouldn't work on 2015s because of the strict canbus system. They also include decoders to sort problems with the other years.
Pneed38
Thanks! I will give it some thought..
Pneed38
Are you stripping parts to oem to sell?
Pneed38
This is my stock headlights. Quad halogens with halogen fogs... Might work? I guess I need to do some research...IMG_20200510_193926.jpg
WhiteNBlackRam
WhiteNBlackRam
Southern California
This is my stock headlights. Quad halogens with halogen fogs... Might work? I guess I need to do some research...View attachment 206731
Those are the exact headlights that would work with this setup. H11 Low Beam. 9005 high beam. 3157 turn signal. And 9006 fogs. Low beams come with decoder. Turn signal comes with required resistors. High beam don’t need decoders biggest problem is getting bulbs to fit underneath the dust cover but these work. Fogs I didn’t need decoder but I’m including canbus decoder in case it’s needed.
Pneed38
Awesome! Thanks for the feedback!! I'm rolling around my money situation.... Don't hold at this point obviously.... Crap!![emoji23]
Rebob0510
Syracuse, NY
Still Available? Ill take the whole bundle. Can send Paypal ASAP.
Thanks,
Rob
Status
