30k handling upgrades
The upper ball joint does take a pretty swift hit with a hammer to knock loose though.
I set them at 6 and haven't really messed with them since. After about 1400 miles they break in and your truck will have a little rake in the front but theres still enough room to clear 35'' tires no problem
WARNING!!! [ Long series of questions incoming! ]
Would it be a good idea to replace the UBalljoint while doing this? Are there balljoint "Upgrades?"
Whats the stock tire size? Are the 35" that much of a difference?
Which tire are you running? Would you pick a different tire now?
I just hit 30k on my 2014 and have been steadily upgrading performance; Diablo, Veraram, catchcan, muffler, 5" tips, OEM lsd diff (coming soon), however I'm starting to come out of the honeymoon phase with this truck!
The ride is too spongey Highway driving is too gooey, quick lane changes over 100mph are sketch. and the rake is starting to get on my nerves. (This is the lowest 4x4 I have ever owned and having to put the truck on ramps to change the oil is ridiculous )
I've read the stock shocks give out after 20 or 30k so I'm goin with the Quicklifts. It also needs new tires. It has the stock wranglers but they are garbage. I cannot believe they ship with that trash.
But since It'll be higher I want to fill that wheel well so it's easier on MY eyes. Hence Bigger tires.
Since its 4x4 gotta get an A/Terrain tire. Since they're A/T gotta lock up the diff. I refuse to have a nonfunctional mall crawler that has to get its hand held through puddles because of open diffs. I know its not gonna be anywhere as capable as a proper 4x4 because of the A$$backwards front diff these trucks have. BUT I cannot be towed out by my friends AWD Hatchback because he has proper LSD on both axles....not again...
Time to drop some $$$ on ol peg legs.
