Random Car Picture Thread
Pretty much the same formula they all used to meet that 305 limit. So far as I know the Chevy DZ302 was the only one to make it into a production car.
Chevy was better off at making a 302 then the other GM divisions as they already had the parts in the parts bin to build a 302,the other divisions were scrambling to come up with an engine that met the 305 cubic inch rule.
In 1986, GM bought Lotus. Not the car company people think of. Lotus Engineering, the consultancy in Hethel, England, that designed suspensions, engines, and chassis for other manufacturers. GM bought them because Chevrolet had a problem: the C4 Corvette needed more power to compete with Ferrari and Porsche, and GM's own powertrain division couldn't build a competitive overhead-cam engine. They considered a turbo V6. Nobody wanted a six-cylinder Corvette. They considered twin-turbo small-blocks. Emissions wouldn't pass. Tony Rudd at Lotus suggested building an entirely new engine from scratch. Lloyd Reuss, head of Chevrolet-Pontiac-Canada, approved it. The result was the LT5: a 5.7-liter all-aluminum DOHC 32-valve V8 designed by Lotus in England that shared exactly one dimension with the existing Corvette small-block (4.40-inch bore spacing) and zero parts.
The LT5 was a clean-sheet design that happened to physically fit in a Corvette engine bay. Aluminum block with Nikasil-coated cylinder liners. Aluminum Rotocast DOHC heads with four valves per cylinder. 11.0:1 compression. Bore: 3.90 inches. Stroke: 3.66 inches. 350 CID. Forged steel crankshaft, forged steel connecting rods, forged aluminum pistons. Three throttle bodies controlled by the ECM based on throttle pedal pressure (one, two, or all three opening progressively). A dual-plenum intake manifold with two-stage runners and sixteen fuel injectors (eight primary, eight secondary). At part throttle, eight injectors and half the intake runners were shut off, limiting output to approximately 200 HP for fuel economy and drivability. At wide-open throttle, all sixteen runners and all sixteen injectors opened: 375 HP at 5,800 RPM and 370 lb-ft at 4,800 RPM.
GM couldn't build it. Their own factories weren't set up for hand-assembled, low-volume, all-aluminum DOHC engines. So they contracted Mercury Marine's MerCruiser division in Stillwater, Oklahoma, a company that built boat engines, to machine and assemble every LT5 by hand. Each engine was individually assembled by a single technician, dynoed, and documented before shipping to the Corvette assembly plant in Bowling Green, Kentucky. The ZR-1 debuted in 1990 and was immediately nicknamed "King of the Hill." At Fort Stockton, Texas on March 1, 1990, a stock ZR-1 set seven international and world speed records verified by the FIA. In 1993, GM upgraded the LT5 to 405 HP with four-bolt main caps, improved heads, revised cam timing, redesigned pistons, and new exhaust manifolds. The target had always been 400 HP. They got there three years late.
Then GM killed it. Internal resentment had been building since the beginning: the most impressive Corvette engine was designed in England by a company GM had to buy and built in Oklahoma by a company that made boat engines. GM's own powertrain engineers had no role. Sales of the ZR-1 collapsed after 1990 (3,032 units in 1990, 502 by 1992, 448 per year through 1995). The LT5 was expensive to produce and limited in volume. Mercury Marine stopped manufacturing LT5s in late 1993, with pre-built engines supplying ZR-1 production through the 1995 model year. Total production: 6,939 ZR-1s. The LT5 was replaced by nothing. The next Corvette returned to pushrod V8s. The next DOHC Corvette engine wouldn't arrive until the LT6 flat-plane-crank V8 in the C8 Z06, twenty-seven years later. Lotus designed it. A boat company built it. GM killed it. The LT5 was the most exotic production Corvette V8 ever made. And GM couldn't wait to forget it.
jawzs2
Air Force
South Jersey
Nice! That looks pretty clean. Needs a 454 though - LOL
What are the letters right above the front marker light? Can't make them out.
HemiLonestar
Navy Badge Coast Guard
MD
And then there was the Snake Skinner.....https://www.corvsport.com/1989-chevrolet-corvette-zr1-snake-skinner/
Ultimately stolen and found in Canadia lol.
If you copy and paste the link it works better. Can't say as i ever heard of it being stolen and found in Canada,but then again i wasn't all that interested in the car at the time,so didn't pay that much attention to it.
HemiLonestar
MD
It's because the link was still connected by dots. Recovered in Toronto. I remember reading about the pursuit at the time and apparently the chopper couldn't keep up with it.
MADDOG
Living in a Firepit
I magnified the pic but I can't tell what it says. Doesn't look stock to me. Maybe it is "305"?
If it's the car i'm thinking about it's 502.Gm built a Monte Carlo to showcase the 502 crate engines when they first came out.
HemiLonestar
MD
Could be but the pic has a standard FB number (672685034_2395534004258448_1627771174176627613_n) so it either came from marketplace or someone's post. GM likely would've done a better job. Probably a custom badge that says 305-350-383.
robertpixie
