acolic
Hi
Can someone confirm my understanding regarding tire sizes.
I’m looking at a 2” to 2.5” lift.
The lift instruction state I can go with:
33 x 12.5 for a 2” lift or
35 x 12.5 for a 2.5” lift.
Using an online tire calculator I came out with the following tire sizes:
275-70-17 32.5 x 11 x 17 my existing tire size
305-70-16 33 x 12.5 2” lift
315-75-16 35 x 12.5 2.5” lift
Questions:
Over stock it looks like the 305-70-16 33 x 12.5 tire is almost the same height as the OEM setup but 30mm wider.
The 315-75-16 is 2.5 cm taller and 40mm wider.
I would need to go with 16” rims for both the 305 and 315 tires.
Make sense?
Thanks
Questions:
Make sense?
Thanks
