Derek Powers
60k miles and mine are junk. Don't want to replace with overpriced factory junk. What are you guys using? Stock height.
If you only putt around to the grocery store and never haul/tow then no. In fact the lower trim levels do not even have a sway bar, at least the early Gen 4s.
Is there a benefit to the core links over the hellwig
Core’s are not adjustable if you decide to move from stock height. The link is 95% in compression or tension so beefing it up is for aesthetics only.
