Rear differential cover for 19+
BigLazer4u
BigLazer4u
North Carolina
Cummins
loves me some nodular iron so i put my own touch on some aev stuff. arp hardware and black paint. nothing fancy
talk to banks today, the rear end has a larger ring gear and the covers from the 2018 will not fit the 2019.
There’s a link to Dethloff’s sway bar spacer in my build thread in my sig
crazy jerry
WY
i thought i made it crystal clear. pw still uses 11.5 14bolt '14-present. the non pw trucks after '18 are using a new rearend. if banks cover is for the 14bolt 11.5 then it fits your pw. banks likely is not familiar with pw. or else you didnt tell him specifically what truck you had
crazy jerry
WY
this was either 19 or 20pw. same axle its always been. you guys are disappointing me with your unwillingness to learn things on your own:banghead:
trdt44
Utah
Below are some pictures showing the different axles. Both trucks were 2020's. Sorry for crappy pictures as they were taken at night. The PWs are a low volume model and most of the manufactures don't pay attention to them. Ton of misinformation.
Power Wagon
Regular 2500
crazy jerry
WY
yes alot of bad info out there. to find the real answers you have to dig into it yourself. i trust no one unless i see it for myself
BigLazer4u
BigLazer4u
North Carolina
Cummins
no I told them exactly the vehicle I had and spoke with an engineer at BANKs.The engineer told me it was different, and this is coming from a company who was trying to sell me a product. Why would they not want me to buy a product?
He was telling me in honesty it was different and not to buy it. I even pointed out your comments in this post to the engineer. After looking at the pictures I get what you are saying. I’ll get the link and post in a minute
BigLazer4u
BigLazer4u
North Carolina
Cummins
Why don’t you call banks tomorrow and discuss this with them since they need to be corrected. and maybe I can get my finned cover then!! Lol.
this is the cover- https://www.bankspower.com/i-2892-d...8-14-bolt-rear-axle.html#wsm-prod-tab-details
it is a 14 bolt 11.5
trdt44
Utah
Unfortunately the engineer does not realize the PW's come with a different axle than regular 2500s. I changed my rear fluid and it took the same gasket as the previous years. I assume they kept the same axle because they did not want to invest in making a new locking differential. I have read that the new axle has 16 ring gear bolts.
Take a look at the diff cover comparison on this webpage. (They don't mention the PW difference either)
https://yourcovers.com/diffcover_11176.php
crazy jerry
WY
they might not of wanted any investment in a new lock mechanism. also the regular 2500 might of got a payload or towing increase that warranted a larger axle. just a guess. pw capacities are well below that of a regular 2500. certainly larger axle isnt needed. on the other hand, sharing common axles would standardize things better. its a double edge sword i guess
SeppW
Northern VA
Hemi 6.4L
So a couple of articles mentions the 5th Gen Wagons do retain the 11.5 AM, albeit one said the pinion angle had been changed to reduce noise and vibration. In another article the standard 2500s are now sporting 12 inch AAMs.
trdt44
Utah
As far as I can tell only the 3500 Cummins HO trucks get the 12" axle. All other trucks (except PW) get the updated 11.5".
retired
montana
double post
