Rear End Replace or Repair
lennyc11
I have 2007 Dod Ram 1500. The rear end locked up. Trying to decide do I have someone rebuild or place? If replaced, do I get a used or reman?
I want to save as much as possible, but I don't want to seek myself short.
Thanks,
L
lennyc11
Thanks 4X4! If I choose to go with a used differential, what should I expect to pay? I assume mileage on the part would determine cost. Also, will the pick and Pull know the gear ratio?
Dodge 1500 4X4
Rochester, NY
Pretty sure there will be a tag on it also it needs to be the same ratio of the front diff, if you have 4X4, price now who knows but cheaper than buying parts!!!
CoachK23
Mississippi
4.7 v8 magnum
A reman will run you around $3000 . If your's isn't rebuildable you will also pay the core charge. I went with LKQ and purchased a used one for around $1300, rotors were in better shape than my old ones too
stevenmicheal
