rear end
angelac
Alberta Canada
2003 Laramie
When I'm driving and step on the gas I feel the truck do like a bouncing as it takes off and once in a while it sounds like it slides into a locking sound almost like its being left behind? I dont know how to explain it but maybe the rear end is burnt out? It doesnt happen all the time.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Not much to go off of here I would love to help but I am not sure I understand exactly what is going on.
angelac
angelac
Alberta Canada
2003 Laramie
It does happen when I accelerate and it doesnt have to be a corner it can be from a red light going straight. Today in the parking lot I put it in reverse back out of my spot put it in drive and as I put my foot on the gas the back end jumped inside like it slipping into drive or something really roughly. And it was slightly turning out to the right to leave so I dont know whats going on.
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
Check your u-joints first. If they are worn out and have a lot of slack in them they will make the "jumping you described. When you say you put it in reverse and it "jumped" that could definitely be u-joint. Its not making a pooping noise by any chance, when you go forward or backwards?
Start with the u-joint and work your way down the drive line to the rear axle. Check to see if the pinion bearings are worn. Just grab the pinion, about where it meets the drive shaft, and pull and push it quickly. Nothing, and I mean nothing, should move when you do this. If it does I would take it to a shop and have it repaired ASAP.
Also check your rear wheel bearing. It is easy to do. Just use a jack and lift the rear wheel off the ground. Grab the tire at the top and bottom and move it back and forth. If you get any movement out of the tires then the rear axle bearing should be changed.
Checking these item will help in your problem solving. Always go with the simple stuff first before you take it to the shop.
Jantelaw
