Rear leaning to drivers side
Bassin12
Have 2017 1500 and noticed truck leaning lower by about an inch on drivers side rear. After doing some research I’ve that this is a pretty common issue! I have Bilstein 5100 in front set at 2.1 and have less than a 1/4 lean in front measurements to wheel wells. My question is has anyone ever install tuftruck 1210’s which they say have a 25% load increase over oem springs in rear and has it fixed the lean.
Thanks
Inside Man
N.E. Ohio
I'm not sure of the brand but I know in the past some have swapped the spring out to level the truck with a full tank.
That being said some of them also had the bed ending up being higher after fuel was depleted.
