Rear spacer or airbags?
Cmsharp
Rogers, AR
Went camping last month with a lot of gear in the bed. Rear suspension had more squat than i would like. The truck is leveled with bilstein's set at 2.1 in the front. I'm guessing I had about 1000 pounds of weight (people/gear/firewood). I've been looking at 1000 pound airbags. Just wondering if a 1 inch rear spacer would do the job instead?
Addicted2fishing
Durham region
HEMI 5.7
Get airbags. You can go the cheap route and install the air lift 1000 which can be bought for probably $80 USD or you can go big with air compressors and 5000 pound bags. From the sounds of it the 1000's would probably suffice for your needs.
Easy install and with a simple air compressor can jack them up. The lines have a T and they pump from the back. There are two little holes on the hitch and from my understanding that's where you install the air cables
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I would say get a good set of air bags, I have Timber Grove air bags and they are very nice.
second for a good set of airbags. I have the TLC airbags. Both the TLC and Timber Grove airbags are a no-cut installation and are easy to install.
Kmiko
