Red Interior LED Bulbs?
AzRamLover
Has anyone replaced their stock map & dome lights with red colored LED equivalents? Red lights are much easier on my eyes at night. Yes, you could disable all the interior lights but then it's totally dark. :(
Tried using 3M red lens tape and the adhesive doesn't hold up to the AZ summers (>115 deg in the shade every day this week), not to mention looking extremely ghetto.
I found these red LEDs at 50 lumens each, but they're really spendy ($12 each!):
Lumen® - Dodge Ram 2014 Map Light LED Bulbs
No luck on finding a red LED replacement for the dome light.
Any suggestions/experiences?
SWJewellTN
Lavergne, TN
Cummins 6.7L
I had red interior lights and red license plate lights on my 2013 BOSS 302. It was indeed a lot easier on the eyes when you flipped them on at night, and it matched the red paint of the car. :)
SitKneelBend
St. Louis
3.6 Pentastar
These. I have used the white version in my truck all over (map lights, license, rambox) and they work great. I'm putting the red ones in just the map lights for the same reason you describe (easier on the eyes at night), but I'm keeping the dome light white.
A
AzRamLover
Here's another suggestion (shameless plagiarized from the other forum) on SuperBrightLEDs.com:
Interior Lights
Overhead Console Lamps TS 212–9 = 4410-CW9 Cool White
Dome Lamp (Map/Courtesy/Reading Light) 7679 = 921-NW12 Natural White
Footwell lights (not mentioned in the OM) 906 = 194 LED Bulb - 10 SMD LED Wedge Base Tower
They appear to have red versions of the overhead console and dome lights but not the footwell lights
SitKneelBend
St. Louis
3.6 Pentastar
moledodge
DAT HEMIIIIIII 5.7
I got mine off of ebay for about 2.50 for the map lights and three bucks for the dome. Make sure you get canbus leds or else they will only come on when the Dorr is open and not when you push the button. Also check your map lights firdt as I guess some are the festooned bulbs. Mine was the push style I believe 194's for the map and then a large festoon for the dome. The only problem is o ordered them from China to save money and had to wait forever for them.
SitKneelBend
St. Louis
3.6 Pentastar
You can get them cheap and quick on Amazon. A pack of 10 LED 194 bulbs is only $13...4 for $7
Sent from my HTC One using Tapatalk
acwood04
ImageUploadedByTapatalk1445406659.924244.jpgImageUploadedByTapatalk1445406681.852708.jpg
I actually got these small 5 mm diameter LEDs on Amazon and wired them to a switch so I can turn them on and off... They are not noticeable from outside the truck, and also they shine just enough light to be able to see in your lap... Pretty happy with hem
JustinRam1500
