Red Rocket Retro's
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
:D
side to side - there is no adjuster for that. the diagonal on the cutoff, those are fun!
Trupiano
Trupiano
Registered User
Hometown : Puyallup,WA Stationed : Little Rock,
2010 Ram 2500 6.7L CTD Crew Cab
6.7L CTD
Ok, so I don't have to worry about anything other than the height? I have the height adjusted almost perfect, and everything else looks just fine. Just didn't remember if you said I had to tweek anything else. Thanks Jeremy!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
it depends on how the rotation looks, and how **** retentive you are.
The cutoffs, you want them to look like this :
a little variation in the horizontal line.......eh - its not going to hurt. As long as they don't aren't cockeyed, its all good man.
xxxotiknightz
Salt Lake City UT,
If I can talk the wife into it and find a set of "loaner" headlights, I'm gonna holler at you for doin a set for her '08 trailblazer
Sent from my iPhone 4 using Tapatalk
make sure you look at them done before you retro them. i was wanting to do the same to my wifes envoy, but after looking at some pics it makes the vehicle looks retarded.
Trup: looks BA.
Trupiano
Trupiano
Registered User
6.7L CTD
Ok awesome! That's pretty much how mine look, thanks again JJ!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Trup: looks BA.
txbass06
NE Texas
5.9 Magnum
Only thing is hers is an '08 and she hasn't found a single aftermarket headlight for hers. On the '08s the grille doesn't extend over the headlights
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Ahhhh. That looks better!
xoom xoom tapatalkin'
Trupiano
Trupiano
Registered User
6.7L CTD
No not yet, gotta replace my garage door first. I was checking out the high beams, and I don't know if it's suppose to be like this or not. But when I hit the high beams, the passengers side cutoff deflector in the projector doesn't move out of the way. It's hard to explain, I think either it's suppose to be like that, or it's defective. Not sure.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I'm willing to bet that the connector for the solenoid came loose, knocked out of the plug, something easy! :birgits_tiredcoffee
Shot over some info, let me know how it goes, and we'll go from there!
