- Jan 17, 2016
- 23,788
- 54,731
- 14 Sport
- 5.7
Just came back from fixing a neighbours stripped out throttle body bolts.Figured i'd repost this pic again of how i repair throttle body bolts that no longer bite into the manifold.
I run a 1/4" tap into the holes,i don't even drill the holes,just run a tap into the existing holes,then cut pieces of 1/4" ready rod/all thread to length,and thread them into the tapped holes,basically creating a threaded stud. If your holes are badly stripped out,and won't grab the ready rod good,you could use some JB Weld and glue them in place,but i've never had any that needed gluing.
It's a better fix then trying to rebuild the plastic holes so that the original bolts will thread back in,and alot cheaper then scrounging up another intake manifold, in my opinion.
Personally i think this is what they should have done instead of the goofy bolts threaded into a composite plastic manifold
A stud into the heat insert would be a very good fix
