The other issue with extreme high efficiency filters is that when they get "their fill" and begin to clog and restrict flow, they will eventually go into bypass.
The issue part is that we have no way of knowing:
1) if a filter goes into bypass;
2) when or for how long a filter went into bypass.
When that valve opens, not only are we pumping unfiltered oil through
our engines, but we are blowing that oil right past all the debris the filter caught, probably pushing out and into the engine.
If I got my hands on a filter that was all that incredibly efficient I would probably get PUP or R&P in quantity and get set up to run 1K OCIs, sort of flush out the engine. Maybe start extending while monitoring the oil on the dipstick as well as what pours out at OCI. 1K to 2k to 3k, etc.
Then switch to HPL and the best syn media filter I can find (for example) once everything looks good. There would be a few UOAs in there as well.
That's my wish list for a lube strategy. I fear it will remain a wish.
